  2. Allegro X Scripting - TCL
  3. Need help , getting one TEXT Object and access properties...
  • State Verified Answer
  • Subscribers 14
  • Views 1838
Need help , getting one TEXT Object and access properties (SETTERS /GETTERS )
Mhawley1
Mhawley1 over 1 year ago
Hello Everyone .
I just started to dive into the TCL scripting language and im hitting some hard walls just because its nothing like the SKILL language . So to get started with something really simple I want to do the following :
I have a DSN , Its completely empty except for a Graphical Object of text .
I want to iterate over the design and read that text and set that text . Thats all . If I can just get that working maybe I can get a grip of how the language works and begin the access other objects . But right now im really struggling with the basics .
  • CadAP
    CadAP over 1 year ago +1 verified
    Hi Mhawley1, Please find a sample tcl code iterating over comment text dumping previous value and changing the value. set lSession $::DboSession_s_pDboSession DboSession -this $lSession set lNullObj…
  • CadAP
    +1 CadAP over 1 year ago
    Hi Mhawley1,
    set lNullObj NULL
    set lStatus [DboState]
    set lDesign [$lSession GetActiveDesign]
    #setting my value in cstring.
    set lMyText [DboTclHelper_sMakeCString "Cadence"]
    #Getting schematic iter.
    set lSchematicIter [$lDesign NewViewsIter $lStatus $::IterDefs_SCHEMATICS]
    #get the first schematic view
    set lView [$lSchematicIter NextView $lStatus]
    # set lPage_Name [DboTclHelper_sMakeCString]
    while { $lView != $lNullObj} {
    #dynamic cast from DboView to DboSchematic
    set lSchematic [DboViewToDboSchematic $lView]
    $lSchematic GetName $lSchi_Name
    set lPagesIter [$lSchematic NewPagesIter $lStatus]
    #get the first page
    set lPage [$lPagesIter NextPage $lStatus]
    # puts [DboTclHelper_sGetConstCharPtr $lSchi_Name]
    while {$lPage!=$lNullObj} {
    # puts [DboTclHelper_sGetConstCharPtr $lPage_Name]
    # set lPartInstsIter [$lPage NewPartInstsIter $lStatus]
    set lCommentsIter [$lPage NewCommentGraphicsIter $lStatus]
    set lGraphic [$lCommentsIter NextCommentGraphic $lStatus]
    while {$lGraphic!=$lNullObj} {
    set lType [$lGraphic GetObjectType]
    if {$lType == $::DboBaseObject_GRAPHIC_COMMENTTEXT_INST} {
    set lTextInst [DboGraphicInstanceToDboGraphicCommentTextInst $lGraphic]
    #Get commnet box dbid
    set lDef [$lTextInst GetDboCommentText]
    #Getting the current value
    set lState [$lDef GetText $lGetCString]
    #COnverting cs string to tcl string.
    puts [DboTclHelper_sGetConstCharPtr $lGetCString]
    #Setting a new value of comment text box
    set lState [$lDef SetText $lMyText]
    if {[$lState OK] == 1} {
    puts "successfully updated the text value"
    #placeholder: do your processing on $lTextInst
    #get the next graphics of the page
    delete_DboPageCommentGraphicsIter $lCommentsIter
    delete_DboSchematicPagesIter $lPagesIter
    #get the next schematic view
    delete_DboLibViewsIter $lSchematicIter
    Hope it helps
  • Mhawley1
    0 Mhawley1 over 1 year ago in reply to CadAP
    YES !!! , this does help thank you so much . I scanned through the code and was intimidated like I knew I would be but I did gleam through one line I really REALLY cared about .
    I started to cobble together a different script and I could not modify text block text and thats the piece I needed . Here the code .
    set lNullObj NULL
    set lObject [GetSelectedObjects]
    puts $lObject
    set lname [DboTclHelper_sMakeCString]
    set lValue [DboTclHelper_sMakeCString]
    set lPropsIter [$lObject NewDisplayPropsIter $lStatus]
    #get the first display property on the object
    set lDProp [$lPropsIter NextProp $lStatus]
    while {$lDProp != $lNullObj } {
    puts "went into while loop iu"
    #can not run
    $lDProp GetName $lname
    $lDProp GetValueString $lValue
    set strName [DboTclHelper_sGetConstCharPtr $lname]
    set strValue [DboTclHelper_sGetConstCharPtr $lValue]
    # puts $strName
    puts [format "%30s = %-30s" GetName $strName]
    puts [format "%30s = %-30s" GetValue $strValue]
    # AH HA < SO NOOWWWWW IT WORKS > MUAHAHAHAH makes all the text TEST
    set name [DboTclHelper_sMakeCString "test"]
    set lState [$lDProp SetValueString $name]
    delete_DboDisplayPropsIter $lPropsIter
    $lStatus -delete
    # note there is also a SETNAME !!!!!! ,
    So in THANK you so much , this gives me a baseline so I can build from there .
