  2. Allegro X Scripting - TCL
  3. How to properly move a part between OLBs with TCL?
  • State Verified Answer
  • Replies 11
  • Subscribers 16
  • Views 10838
andakConsultingLtd
andakConsultingLtd over 1 year ago
I am trying to clean up some old libraries i.e. move unused parts from active.olb to unused.olb. The code is presented below. Everything works pretty well except that there is something hanging inside active.olb that prevents creating a part that was there before. E.g. if PART_123 was moved from active olb to unused.olb, I can not create PART_123 again. If I look inside active.olb file, PART_123 is still mentioned, despite not being shown in the lib tree structure. I guess I am missing some cleanup in my code, but I can't figure what exactly, so I am asking for your help.
set lSession [DboTclHelper_sCreateSession]
set lStatus [DboState]
set lNullObj NULL
#Provide the location of olb FROM which package should be copied.
set lSourceLibPath [file normalize {D:\ACTIVE.OLB}]
set lSourceLibPathCstring [DboTclHelper_sMakeCString $lSourceLibPath]
set lSourceLib [$lSession GetLib $lSourceLibPathCstring $lStatus]
#Provide the location of olb TO which package should be copied.
set lDestnLibPath [file normalize {D:\UNUSED.OLB}]
set lDsctnLibPathCstring [DboTclHelper_sMakeCString $lDestnLibPath]
set lDestnLib [$lSession GetLib $lDsctnLibPathCstring $lStatus]
#parse all packages in the olb
set pkgIter [$lSourceLib NewPackagesIter $lStatus]
set pPkg [$pkgIter NextPackage $lStatus]
while {$pPkg!=$lNullObj} {
    set pActualPkgName [DboTclHelper_sMakeCString]
    $pPkg GetName $pActualPkgName
    $lDestnLib CopyPackageAll $pPkg $pActualPkgName $lStatus
    $lSourceLib DeletePackage $pPkg
    puts [DboTclHelper_sGetConstCharPtr $pActualPkgName]
$lDestnLib MarkModified
$lSourceLib MarkModified
$lSession MarkAllLibForSave $lDestnLib
$lSession SaveLib $lDestnLib
$lSession RemoveLib $lDestnLib
$lSession MarkAllLibForSave $lSourceLib
$lSession SaveLib $lSourceLib
$lSession RemoveLib $lSourceLib
DboTclHelper_sDeleteSession $lSession
  • CadAP
    CadAP over 1 year ago in reply to andakConsultingLtd +1
    andakConsultingLtd Please use below code to delete the package set lSession $::DboSession_s_pDboSession DboSession -this $lSession set lNullObj NULL set lOlbName "test.olb" ; #provide your library…
  • PatEscher
    PatEscher over 1 year ago in reply to andakConsultingLtd +1 verified
    use DeletePackageAll
  • KD202502275710
    0 KD202502275710 over 1 year ago in reply to CadAP
    This is helpful CadAP
  • andakConsultingLtd
    0 andakConsultingLtd over 1 year ago in reply to CadAP
    Hi there,
    1. Copy an existing OLB file to the test location, one that has a few parts in it
    2. Open this OLB in Capture
    3. Delete all existing parts in the library, to start from scratch
    4. Create 2 new parts: PART_ABC and PART_123
    5. Close parts and save library
    6. Load/run the tcl script with source {scriptName.tcl} (result below)
    7. Save OLB and then Right click the libary to create again PART_ABC (see image below)
    8. I get the error as shown
    Step 4:
    Step 5, before running script:
    result after step 6:
    step 7:
    Step 8:
    After step 6, if you open the OLB with a text editor, you can still see PART_ABC and PART_123 mentioned in the file, despite them being deleted, and I think this is what causes the error.
    0 andakConsultingLtd over 1 year ago in reply to andakConsultingLtd
    Hi CadAP , did you have the chance to replicate the issue?
  • CadAP
    0 CadAP over 1 year ago in reply to andakConsultingLtd
    andakConsultingLtd
    Please below api instead of DeletePackage:
    RemovePackage(pPackage) : returns DboState
    Class : DboLib(DboBaseObject):
    Parameters:
    pPackage: DboPackage *
    $lDboLibrary DeletePackage $pPackage
    $lDboLibrary RemovePackage $pPackage
    Once done save and close the library and reopen it again
    Hope it helps.
  • PatEscher
    +1 PatEscher over 1 year ago in reply to andakConsultingLtd
