  2. Allegro X Scripting - TCL
  3. How to properly move a part between OLBs with TCL?
  • State Verified Answer
  • Replies 11
  • Subscribers 16
  • Views 10846
andakConsultingLtd
andakConsultingLtd over 1 year ago
I am trying to clean up some old libraries i.e. move unused parts from active.olb to unused.olb. The code is presented below. Everything works pretty well except that there is something hanging inside active.olb that prevents creating a part that was there before. E.g. if PART_123 was moved from active olb to unused.olb, I can not create PART_123 again. If I look inside active.olb file, PART_123 is still mentioned, despite not being shown in the lib tree structure. I guess I am missing some cleanup in my code, but I can't figure what exactly, so I am asking for your help.
set lSession [DboTclHelper_sCreateSession]
set lStatus [DboState]
set lNullObj NULL
#Provide the location of olb FROM which package should be copied.
set lSourceLibPath [file normalize {D:\ACTIVE.OLB}]
set lSourceLibPathCstring [DboTclHelper_sMakeCString $lSourceLibPath]
set lSourceLib [$lSession GetLib $lSourceLibPathCstring $lStatus]
#Provide the location of olb TO which package should be copied.
set lDestnLibPath [file normalize {D:\UNUSED.OLB}]
set lDsctnLibPathCstring [DboTclHelper_sMakeCString $lDestnLibPath]
set lDestnLib [$lSession GetLib $lDsctnLibPathCstring $lStatus]
#parse all packages in the olb
set pkgIter [$lSourceLib NewPackagesIter $lStatus]
set pPkg [$pkgIter NextPackage $lStatus]
while {$pPkg!=$lNullObj} {
    set pActualPkgName [DboTclHelper_sMakeCString]
    $pPkg GetName $pActualPkgName
    $lDestnLib CopyPackageAll $pPkg $pActualPkgName $lStatus
    $lSourceLib DeletePackage $pPkg
    puts [DboTclHelper_sGetConstCharPtr $pActualPkgName]
$lDestnLib MarkModified
$lSourceLib MarkModified
$lSession MarkAllLibForSave $lDestnLib
$lSession SaveLib $lDestnLib
$lSession RemoveLib $lDestnLib
$lSession MarkAllLibForSave $lSourceLib
$lSession SaveLib $lSourceLib
$lSession RemoveLib $lSourceLib
DboTclHelper_sDeleteSession $lSession
  • CadAP
    CadAP over 1 year ago in reply to andakConsultingLtd +1
    andakConsultingLtd Please use below code to delete the package set lSession $::DboSession_s_pDboSession DboSession -this $lSession set lNullObj NULL set lOlbName "test.olb" ; #provide your library…
  • PatEscher
    PatEscher over 1 year ago in reply to andakConsultingLtd +1 verified
    use DeletePackageAll
  • andakConsultingLtd
    0 andakConsultingLtd over 1 year ago in reply to PatEscher
    YESSSS!
    This is doing the right thing!
