  2. Allegro X Scripting - TCL
  3. Constraint setup via TCL in ASC?
  • Subscribers 14
  • Views 488
Gelzone
Gelzone 4 months ago
I need to do a manual process for each schematic: Electrical Analysis -> Constraint Manager -> Edit -> a window popup (the screenshot) -> Tools -> Options and check the items below:
I found it is not a global setting so I need to set this one by one.
I'd like to know is there any command/script can handle this? I just find cnsmgr to open the window but can not manipulate the choice.
Or another way, if ASC has a config file just like OrCAD's Capture.ini? Maybe I can set them in this kind of file.
  • Gelzone
    0 Gelzone 4 months ago
    The English ver: Applications of Electrical Constraint Sets for the first section; Automatic Topology and Updates for the first selection; Creating XNet and Differential Pairs Using the DML Model (same with SPB 16.6) for the second selection
