  3. ERROR (SPDWSRV-000502): Unable to authenticate because the...
  • Subscribers 31
  • Views 4539
ERROR (SPDWSRV-000502): Unable to authenticate because the connection to https://pcb.cadence.com/unifiedsearch failed. Check that the server is up and running.
jishu
jishu over 5 years ago
Hello World,
while using the unified search i get an error while login : ERROR (SPDWSRV-000502): Unable to authenticate because the connection to pcb.cadence.com/unifiedsearch failed. Check that the server is up and running..
I have checked my Pulse is running and even restarted the pulse, still it shows the same error.
how can i resolve this?
Jishu
  • KOLEN
    0 KOLEN over 5 years ago
    Hi to all,
    i have similar issue with search providers function. It does not work, but the error is: SPDWSRV-000510 “Connection Timed Out".
    I have found 504 - connection timed out error when simple type: pcb.cadence.com at any of my browsers installed on my PC. I see the same error even when I use my phone. It means, it is not blocked by my office network.
    Morevoer ping to 54.239.192.66 work pretty fine
    Do you have any suggestions, how to resolve this issue?
    Best regards
    Darek
  • KOLEN
    0 KOLEN over 5 years ago in reply to KOLEN
    Small update. It seems to work now. Unfortunatelly, can not say why. Will share, when I find it
  • AvengerThanos
    0 AvengerThanos over 5 years ago in reply to KOLEN
    What caused the issue ?
  • KOLEN
    0 KOLEN over 5 years ago in reply to AvengerThanos
    I do not know. It just works now, It has started to work in the same way it had stopped. Out of the blue.
    I wish I could share more precise info.
