  3. Why to use Allegro System Capture – Version Control
  • Subscribers 31
  • Views 10231
DesignTech
DesignTech over 4 years ago
During the design phase, it is required to maintain multiple versions of the design.
System Capture provides a version control functionality. Designers can use this feature to maintain versions of the design as well as see the design changes for each version.
Versions of the design are created when you select Save All or Commit.
Save All
Saved versions are created when you select File > Save All. These versions are visible only to the user who creates them.
The saved versions are represented by the branches to the right or left of the vertical line in the center of the version control tree as shown below:
The name of the user who created this version is also shown.
Commit
Commit versions are created when you select File > Commit. You can choose to create major or minor versions of the design based on your selection in the Commit form.
You can revert to older versions of the design by selecting the required version in the version history in System Capture.
When the design is saved in the Pulse environment, the commit versions can be seen by all members of the design team the design is shared with.
To identify versions of the design in the version history, you can add notes and tags while committing the design. Hover over the versions to get the details.
Team DesignTech
Cadence Design Systems
  • Schulz Jordan
    Schulz Jordan over 4 years ago
    Any plans of introducing version control in schematic capture ?
  • atishcdns
    atishcdns over 4 years ago in reply to Schulz Jordan
    Allegro System Capture is a schematic capture tool that has the versioning feature using the option Save All or Commit
  • Schulz Jordan
    Schulz Jordan over 4 years ago in reply to atishcdns
    Schematic capture I mean here is OrCAD Capture
