  2. Design Entry HDL
  3. Repeated Delete and Move commands
  • State Verified Answer
  • Subscribers 24
  • Views 9274
stinkindiesel
stinkindiesel over 3 years ago
I've recently migrated to 22.1 from 17.4, and some things are not working the way I'd like. The most annoying seems to be the loss of a repeated move or delete command.
In 17.4 and earlier, if I selected Move from the right mouse pop-up menu, I was in move command until I changed commands, hit <ESC> or hit right mouse pop-up -> Done. Now, I get one move and it automatically reverts back to waiting for another command. If I want to move multiple objects, I have to keep selecting Move before every object.
Delete is similar. Back in 17.4, I got a single delete if I used the right mouse pop-up, but typing Del in the command window would keep me in delete mode until I terminated the command.
I'm sure there's a command or attribute to get me back to the way 17.4 operated, but I'll be darned if I can find it. Something similar to copy repeat. Can anyone help?
Thanks.
  • rg13
    rg13 over 3 years ago +1 verified
    Try disabling ' Enable Pre-select mode ' in Tools > Options in DE-HDL After disabling, click on Apply and then OK. Now apply Del command in console window, it will keep deleting components on select…
  • rg13
    +1 rg13 over 3 years ago
    Try disabling 'Enable Pre-select mode' in Tools > Options in DE-HDL
    Now apply Del command in console window, it will keep deleting components on select until you terminate the command by ESC or RMB > Done.
    Hope it helps!
  • stinkindiesel
    0 stinkindiesel over 3 years ago in reply to rg13
    Thanks. I didn't realize this was on after the upgrade. I must have looked at this a dozen times and never noticed it was checked! I guess you see what you want instead of what's there...
