  2. Design Entry HDL
  3. How to create a compressed BOM in Allegro schematic in Design...
  • State Suggested Answer
  • Answers 1
  • Subscribers 24
  • Views 8032
How to create a compressed BOM in Allegro schematic in Design Entry
heidi099
heidi099 over 2 years ago
I am using the Allegro Design Authoring : Design Entry HDL and I have a compiled and annotated schematic.
I want to create BOM.
Part1, 3, R1, R2, R3
Part2 , 4, C1, C2, C3, C4
Part3 , 1 C10, C11
etc
How do I set up the template to create such an output.
  • rg13
    rg13 over 2 years ago in reply to heidi099 +1 suggested
    Refer below settings: It seems that you have selected Unique radio button under RefDes. Try to have setting as shown in above image and see if it helps.
  • rg13
    0 rg13 over 2 years ago
    If you want to have components separated based on their value in BOM, you can 'customize' template and choose 'value' under 'Physical part Specifications' as shown below:
    After it, you will find BOM as follows:
    Hope it helps!
  • heidi099
    0 heidi099 over 2 years ago in reply to rg13
    I was created as shown in the picture below.
    How can I get RefDes with the same part number in the same compartment?
    partnumber, value , RefDes, Qcy
    001001, 200k, R1 R2 R3, 3
    001002, 100N, C1 C2, 2
    What filter should I add?
  • rg13
    0 rg13 over 2 years ago in reply to heidi099
