  2. Design Entry HDL
  3. Not add suffix to a subdesign
  • State Verified Answer
  • Subscribers 24
  • Views 8380
AB_1720516286397
AB_1720516286397 over 2 years ago
Hi all,
I have two sub-designs.
I have added SUBDESIGN_SUFFIX property for one of them manually.
I only instantiated once the other one and I don't want to add suffix to this one.
Is there any way to do that.
Really appreciate your quick answers.
Thank you in advance.
  • rg13
    rg13 over 2 years ago in reply to AB_1720516286397 +1 verified
    If you want to maintain a hierarchy and want incremental unique reference designators at multiple hierarchies without any suffix, you should not apply/use the SUBDESIGN concept. You should not use GENERATE…
  • rg13
    0 rg13 over 2 years ago
    You mentioned that you have two sub-designs. Do you mean, two identical hierarchical blocks (sub-designs), you have placed on schematic and on one of them , you have defined SUBDESIGN_SUFFIX property and on other one you have not, right?
  • AB_1720516286397
    0 AB_1720516286397 over 2 years ago in reply to rg13
    No, they are not identical.
    But for one of them I don't want to add any suffix.
    For example if I have U1 in the subdesign, I want to keep U1 after packaging the top level design.
  • rg13
    +1 rg13 over 2 years ago in reply to AB_1720516286397
    You should not use GENERATE/FORCE/USE SUBDESIGN at any level while packaging and directly go for 'Generate view' to create the hierarchical block.
    Also, don't use SUBDESIGN_SUFFIX attribute at block level.
  • AB_1720516286397
    Thanks.
    That's the solution.
