  3. Illegal section pin value - Design Entry CIS
  • Views 1269
sigit
sigit over 16 years ago
Dear all,
When I tried to generate netlist for (Allegro) PCB Editor
v16.0, I had this messages :
Loading... E:\.........\ SKEMATIK\ NETLIST_VER1_ REPLACED_ COMP/pstxnet. dat
packaging the design view...Illegal section pin value
Does anyone know what it means? is it an error or just warnings?
FYI, the netlist is successfully generated and I can do import netlist in Allegro PCB Editor,  but I'm still curious about the messages
many thanks,
sigit
  • oldmouldy
    oldmouldy over 16 years ago
    Just a guess but hard to tell anything without seeing the source design.
    Check that you have the latest service release, for 16.0, that was issued at the end of March and can be downloaded from the downloads site with a Sourcelink account, or download and install 16.01 and it's latest service release, if the DE CIS version is .p001, that will be a base release and may be the problem.
    Something else to try is the "other" netlist tab, select the "wirelist.dll" for a simple text netlist, this may flag the issue. Generally, it would be unusual for the PCB Editor netlist to be generated if there were any issues with the data. Since the error looks to be from the pstxnet checking, the issue could be a pin number or inconsistent pin properties, not too easy to create with the tool.
  • sigit
     Yes,my DE CIS version is .p001. I've tried to generate netlist by selecting the "wirelist.dll", and it seems okay. All I have is just this messages :
    Netlist Format: wirelist.dll
    Design Name: E:\.......\SKEMATIK\BOARD_VS_VER1_FINAL.DSN
    774 Parts, 54 Library Parts, 786 Nets, 3743 Pins
    Initialize
    WARNING: Name is too long 'DIFFIO_R30p/DQS1R', truncated to DIFFIO_R30p/DQS
    WARNING: Name is too long 'DIFFIO_R16n(x/x/IO)', truncated to DIFFIO_R16n(x/x
    WARNING: Name is too long 'DIFFIO_R26n(NC/NC/x)', truncated to DIFFIO_R26n(NC/
    DONE
    I'll try the latest service release for 16.0 and find out the outcome. Thanks a lot.
