  3. DRC reporting phantom Unconnected Pin errors
  • Subscribers 167
  • Views 15051
mvonahnen
mvonahnen over 16 years ago
 I have am in the process of finishing up my routing so I am using the Unconnected Pin report to find my missing connections.  Unfortunately, the first 3 ones I have checked are all phantom, the connection is there and the report is incorrect.
 Is there any special configuration for this report?  Is there something like the trace has go to the center of the pin?  I am confused because the ones I have checked are obviously connected.
  • steve
    steve over 16 years ago
    The report is always correct. You need to ensure that you connect to the centre of the pad to make the connection, alternatively you could get close then RMB finish.
    Regards
    Steve
  • mvonahnen
     RMB FInish?
  • steve
    In versions 16.x onwards you can right mouse button then get a list of commands. Finish will finish your route for you.
  • Ejlersen
    Ejlersen over 16 years ago
    RMB is right mouse button
  • Ejlersen
    One important thing to check for during interactive routing is that "snap to connect point" is checked in the 'options panel'
    If this is not the case, then the cline may finish whereever you click inside the pad.
