  3. Top vs Inner Dynamic Shape Connection Help
  • Replies 8
  • Subscribers 166
  • Views 16778
tkeebler
tkeebler over 17 years ago
Hey all, I'm looking for a little help (I'm new to Orcad, so forgive my ignorance in advance).
 I'm using Orcad PCB Editor 15.7 and designing a 4-layer board.  Routing is on the top and bottom layers, and the two inner layers are GND and 5V_VDD.  I've routed all my signals and now I am trying to add the fills/shapes for the two inner layers by drawing dynamic copper shapes which are assigned to my net of interest (GND or 5V_VDD).
Testing this method out on the top layer does precisely what I would like:
Top
The three pads which are GND in this example are connected to the rectangle shape, but the one that isn't is isolated, along with its trace.
The problem is that when I do this on the inner layer, it seems to just create a solid rectangle of etch:
Inner
 When I do this, the ratsnet disappears as if the nets are connected, and doesn't give me other errors when I generate reports, but when I generate the gerbers/artwork for the inner layers, it doesn't show exclusions for the vias/pads/holes that aren't supposed to be connected to the inner layers.
I can't figure out why this is occuring... am I missing a setting, or am I generating the gerbers wrong.... or what?
 Thanks very much for the help, this has brought my project to a halt and after spending a day googling for answers and poking around the program I can't figure out what the problem is.
 -Todd
  • Khurana
    Khurana over 17 years ago
    In Layout Cross Section (Setup > Cross-section) deselect Negative artwork for the plane layer.
  • Khurana
    Forgot to mention that the padstack will now require a flash symbol to show thermal ties (spokes) otherwise you will get crosshair cursor to denote a connection between pin and shape.
  • tkeebler
     Thanks a lot.
     Unfortunately, my version of Orcad does not have a cross-section setting under the setup menu.
     I have:
    Drawing size
    Drawing Options
    Text Sizes
    Grids
    Subclasses
    Define B/B Via
    Constraints
    Property Definitions
    Define Lists
    Areas
    Outlines
    User Preferences
    I looked in most of those and couldn't find any settings referring to "cross-sections".  Any ideas?
    -Todd
  • Khurana
     Oh Ok (sorry).  Go to Tools > Setup Advisor > click Next > click Edit Cross-section.
  • Khurana
    You may also access cross-section (in v16.2) by clicking Setup > Subclasses > click Etch button.
