  3. Deleting a pin from a package symbol
  • Views 17554
Kroum
Kroum over 16 years ago
 Using PCB editor 16.0. New to OrCAD PCB. Having two problems for now.
First one:
Need to create a new footprint. It would be much faster if I was able to edit an existing dra file (to delete two pins and the package boundary and then to add two pins and a new package boundary). I was able to delete the existing package boundary, but I couldn't figure out how to delete the two pins.
I am using the following procedure to delete a pin:
  1. Select the pin.
  2. Edit – Delete
The message I am getting is:
Selected item not valid for current operation, ignored: Mechanical Pin "Hole100"
No valid items selected for the current operation, exiting.
The second problem is similar to the first one. I am trying the modify a brd file, containing the board outline, several connectors and several package keepout areas. Need to replace one of the connectors with another one, but I cannot figure out how to delete the existing footprint. Using the above procedure (selecting the package symbol first and then Edit – Delete, I am getting the message:
Selected item not valid for current operation, ignored: Symbol "J*"
Obviously the correct procedure is different than the one I am using, but I cannot figure out it and need help.
Kroum
  • pakistan
    pakistan over 16 years ago
    your have to edit dra file to delete pins, pins cant be deleted in a brd file you should open dra file then go to edit>delete and check on "pins" in find tab and and then click on the pin which you want to delete. After editing you have to save te component and if number of pins changed then you have to edit schematic too. Now you have to update symbol on brd file.
    on brd file go to edit>delete then go to find tab and check "symbol" and click on the symbols which you want to delete for updating.
    then load netlist again and place te components again.
    there could be a better way if any one knows plz let us know
    Regards
    Tanveer
  • Kroum
     Thanks Tanveer! It works!
    When I first read your answer, I thought I was doing exactly what you are suggesting. Then I realized your suggestion was first to select the action (delete) and then – the object to delete (the pin). I was trying the reversed sequence - first selecting the object (the pin), then - the action (delete) and it wasn't working.
    Kroum
