  3. Method of manually assigning connectivity within the PCB...
  • Views 13500
Method of manually assigning connectivity within the PCB Editor?
KerryMurphy
KerryMurphy over 16 years ago
All:
 I'm using V15.2 of Cadence, and from all I've looked through there doesn't seem to be a method to manually assign connectivity to parts you would load from a library into the PCB editor. Having used other tools previously [only using Cadence now since 11/08] there was always a method of doing this task. I figure if you can load parts w/o a netlist packaged from the schematic then you can add connectivity as well. Is this tool capable of this? Maybe available in newer revs possibly? Thanks in advance for your assistance to this Cadence newbie :).
  • Randy R
    Randy R over 16 years ago
    See if this works:
    1) Setup->User Preferences->Misc and check the box for "logic_edit_enabled"
    2) Logic->Net Logic
  • redwire
    redwire over 16 years ago
     Must have appropriate license level for net logic editing.
  • Ejlersen
    Ejlersen over 16 years ago
    To use Net Logic you need Allegro PCB Performance Option or Allegro PCB XL/GXL
    Br,
    Ole
