  3. Error while converting from Orcad layout(v9.1 to Allegro...
  • Views 919
Error while converting from Orcad layout(v9.1 to Allegro v16.2)
rame
rame over 16 years ago
Hi Folks,
 I converted the Pcb file from Orcad Layout to Allegro ver 16.2.As told by  someone in   this   forum, it doesn't convert exactly as you see in the Orcad Layout. Two layer card  in orcad when converted became 6 layers, with what ever work around method known to me, i tried to delete the middle layers,but then in vain.As it is working Card in orcad,we would like to convert it to Allegro exactly with no changes whatsoever..To my observation i see most of it have been converted,with only few exceptional like board outline,layerstackup,footprint padstackup etc..
If someone who already have done the conversion from orcad to allegro,lease help me out...
 Thanks & Best Regards,
 Ramesh
  • oldmouldy
    oldmouldy over 16 years ago
    Make sure that the settings are correct in Layout, the translation to PCB Editor will not add any layers. Go to the Layers spreadsheet in Layout and change the copper layers other than TOP and BOTTOM to "unused".
  • rame
     Hi Oldmouldy,
     Thanks a lot,i tried your steps and its working fine now,Can you kindly tell me the other steps too which will retain my entire data  conversion to Allegro 16.2.
    I am newbie in Orcad layout,since its an working board in orcad we like to have entire board converted to Allegro,and changes will be kept to minimum.
    Ramesh
