  3. E- (SPMHGE-82) error while placing part manually
  • Views 4050
terrylau
terrylau over 16 years ago
I encounter this error when I tried to places a part manually.
E- (SPMHGE-82): Pin numbers do not match between symbol and component. Run dev_check on device file for more information.
When I ran the Netlist in Design Entry CIS, everything netlisted fine with no errors. Only when I removed the an old part and tried to update the new part manually, I have this problem.
Can anyone tell me how to run the dev_check? Thanks in advance.
  • oldmouldy
    oldmouldy over 16 years ago
    Which version are you using?
    The CIS<>PCB Editor flow won't be using device files, these are only used with the HDL and third-party flows.
    The problem will be that the Pin Names / Numbers do not exactly match between the schematic part and the footprint.
    When you "removed the old part" was this in CIS or PCB Editor? In PCB Editor, you can only unplace components since the netlist needs to come from the front end to effect changes.
  • Cadpro2K
    Cadpro2K over 16 years ago
    My guesstimate would be:
    1) old part on the layout came from some other library (local drive maybe), and doesn't match the 'true' master library part.
    2) someone changed the library symbol in the library.
    Easy check, is to look at the footprint you think you're pointing to (master library), and compare that to the part section in the pstchip.dat file you import (look at the pins section). Something must be weird. Either the library footprint, the netlist, or your pointers.
    M
