  3. creating vias
  • Subscribers 166
  • Views 13084
creating vias
parchus
parchus over 16 years ago
How to create and edit vias in pcb editor?? can somebody help me plz...
  • steve
    steve over 16 years ago
    There is a stand-alone software called PAD Designer that is found under pcb editor utilities that will create pad files for you. Once you have created the padstack, save it at your padpath location, then add it to the physcial rule (PCS) in constraint manager. Once in a design you can edit padstacks using tools - padstack - modify design padstack (which launches pad designer).
  • ELEKVN
    ELEKVN over 16 years ago
    You can create padstack here: Cadence SPB 16.0/ PCB Editor/ Pad Designer.
    And modified here: Tools/  Padstack/Modied padstack
    Have nice time
    Elek
  • parchus
    Thank you Elek
    Suresh.P
