  3. Need Help with PCB SI
  • Views 12932
archive over 16 years ago
   I have used HyperLynx in the past to do SI. Now I have to use PCB SI. My flow with HyperLynx was to read in the design then run a batch mode simulation. Based on the results from the batch mode then I would pick a net at a time and run detailed analysis. Is there a feature like that in PCB SI where I can run a batch simulation that will do Reflection and Crosstalk on the entire design.
Thank You
Sudhir
  • Mike Veal
    Mike Veal over 16 years ago
     Hi Sudhir,
    Not exactly.
    You can use constraint manager though, set up your crosstalk, reflection criteria as constraints in a EC Set then apply that ECet to the nets that you are concerned about. CM will then do all the simulations and highlight red the nets that fail your constraints. If you want to look at waveforem on these, you will have to simulate each individually.
     Hope that helps,
  • Dennis Nagle
    Dennis Nagle over 16 years ago
    Hi Sudhir,
     What license do you have? There are both interactive and a batch command options available depending on what you have.
    -Dennis
    Hi Dennis
    We have PCB SI L. If I have PCB SI L what is my flow. The tutorial talks about Allegro PCB  Editor which I cannot open. Which tool do I use to open the .brd file ?
    Thank You
    Sudhir
  • Dennis Nagle
    Hate to keep peppering you with questions - but what release are we talking ?
    You should be able to open the .brd file with PCB SI from the start menu or try "allegro -sq" from the command line. The tutorial is out dated and refers to a time when the "L" version only contained SigXplorer.
    -Dennis
    HI Dennis
    I am running 16.2 . Here are my license features, I cannot open PCB SI tool that is installed on my machine with the license I have.
    # Product Id  : PS3400,  [Version: 16.2]
    # Product Name: Allegro(R) PCB SI - L
    # Product Type: Floating                     Exp Date: 29-aug-2009  Product Qty: 1
    # Product Comments:
    #   Feature: plotVersa                       [Version:  93.040] [Feature Qty Per Product:  2]
    #   Feature: Allegro_Viewer_Plus             [Version:  16.200] [Feature Qty Per Product:  1]
    #   Feature: SPECCTRAQuest_signal_explorer   [Version:  16.200] [Feature Qty Per Product:  1]
