  3. Thermal relief clearance
  • Subscribers 166
  • Views 15377
bulldog
bulldog over 16 years ago
I was wondering if anybody knows what the IPC recommended clearance is for a thermal relief around pads.  Thanks!
  • steve
    steve over 16 years ago
    I don't believe there is an IPC standard. Yo could try having a look at PCB matrix. There is a free IPC Calculator which may give clearances for theremal reliefs. I would always use the manufacturers minmum line-pad spacing as a starting point.....
  • bulldog
    Thanks Steve, I'll look into it.
    From what I have been able to find it looks like most vendors prefer a minimum of .010" with a desire for .012".
  • hcowles
    hcowles over 16 years ago
    at the pcbmatrix website http://www.pcbmatrix.com/Downloads/GeneralDocuments.asp
    the padstacks document contains the IPC-7251 Padstack Charts (locked).xls that has the recommended padstack parameters for all 3 levels (most, nominal, least) of padstacks
    created by PCB Matrix using IPC-2221 IPC-7251 PTH Padstack table for levels A, B, C
  • Nagaraj Shanmu
    Nagaraj Shanmu over 16 years ago
    Have a look at this , gives information on thermal relief calculation.
    http://www.pcbmatrix.com/forum/forum_posts.asp?TID=2200
    ~Nagaraj
