  3. Fix error in schematic HDL
  • Replies 7
  • Views 18672
ELEKVN
ELEKVN over 16 years ago
Hi all, I am a new designer in HDL, so I need more help from you Can you help me fix this error? "ERROR(SPCOCN-1993): An error occurred because no value was specified for a placeholder (?). Make sure that you specify a valid value for the placeholder. (placeholderprops)" Where is ERROR(SPCOCN-1993) in help of Cadence tks
  • Jerry GenPart
    Jerry GenPart over 16 years ago
    I'm not near my work computer today, so I can't look-up the exact error, but this means that a property exists on the symbol with a value of "?". You need to replace this ? Value with a real value. Typically, this is done by selecting a row from the part table when adding the part via the Component Browser. Try doing this, save the page, and run Export Physical again.
    Jerry Grzenia
  • ELEKVN
    tks for your help I will do it base on your recommand Have nice week
  • ELEKVN
    HI, Please help me. Please see file error_reference.pdf Can you tell me where i can add reference U3 for I3 same as u1 for i1 and U2 for I2. It is current error. "ERROR(SPCOCN-1993): An error occurred because no value was specified for a placeholder (?). Make sure that you specify a valid value for the placeholder. (placeholderprops)"
    error_reference.pdf
  • Jerry GenPart
     Hi Luan,
    You can use the DEHDL Attribute command. Click on the part with the I3 PATH property. Then, assign a
    LOCATION property with the value U3 in the Attribute form.
    Jerry
  • ELEKVN
    Dear Jerry
    thak you for your help.
    I am sorry to bother you.
    I did base on your command but this error is still.
    I think it come from package.
    I want to sent you this package, but i can't attach folder file. Can you tell how to send this package to you.
    Can you share you mail address
    Thank you
    Elek
