  3. Properties in Concept
  • Views 14407
ELEKVN
ELEKVN over 16 years ago
Hi all, I am a new concept designer? I don't now what is different " key properties" and "injected properties" in concept symbol? When will we use them? Can you help me? How can I add one file *.ptf (part table file) to one symbol? Mean that, I want all file *.ptf of one project put in one folder. How can i attacted those file to each different symbol. Thank you Have a great weekend Elek
  • Mike Veal
    Mike Veal over 16 years ago
     Hi Elek,
    Part table files can be either library level or cell level. There are advantages and disadvantages with both techniques.
    With a library level ptf, there is a single ptf file that includes ptf entries for every component in your library.
    The cell level ptf is stored with each schematic symbol. In this scheme, each cell level ptf contains only entries for those components associated with that schematic symbol.
     You are free to choose whichever scheme you wish.
    Looking into the ptf, each component will have one or more lines. On each line, there are a number of values, an "=" sign and more values after the "=" sign.
    The values on the left of the "=" are written to the schematic.
    The values on the right of the "=" are read by the packager when you export your design to the PCB tool, or create a bill of materials.
    You say you want to put all the part table files associated with a single project in one folder. That's a lot of work, and I don't know why you'd want to. Are you sure you don't just want a bill of materials? Compile the design and then run the BOM tool.
    Hope that helps.
  • Jerry GenPart
    Jerry GenPart over 16 years ago
    In addition to Mike's repy (very good summary by the way!), the "key" properties are those that appear on the left hand side of the "=" in the part table file, and the "injected" properties are those that appear on the right hand side of the "=" in the part table file.
    There are a couple of special part table file characteristics (adding properties to just one row in the PTF file), but I'd recommend you review the Cadence Manual for details.
    Jerry
  • ELEKVN
    Thank for all your help. Hi Jerry, can you tell me where can I get imformation about "Cadence Manual " Thank
  • ELEKVN
    Thank you Mike, Yes i want to creat With a library level ptf, there is a single ptf file that includes ptf entries for every component in your library. Can you help me. Where can i create it Elek
  • Jerry GenPart
    Sure -
    When you're working in any of the SPB products, look for the Help menu item.
    Select that, then from the pull-down list, look for Cadence Documentation.
    That will be the local online manual for the product you're currently using.
    You can also invoke the manuals from the Windows "Start" menu.
    You can also search the manuals via Cadence Online Support at http://support.cadence.com.
    Jerry
