  3. Symbol and Footprint won't connected - PCB Editor 16.2
  • Replies 9
  • Subscribers 163
  • Views 5062
shangwu
shangwu over 16 years ago
I have a one-pin schematic symbol and a one-pin footprint (used as a test point), but they just can't connect together in PCB Editor 16.2.
In Capture, I connect the symbol to a net (+15f), which has several other parts connected.
After forward annotated to the PCB Editor, everything is fine except this single-pin footprint that wouldn't connect to the net (+15f).  I checked its net name in PCB Editor, it showed +15f_10944596.  Where does the extra number come from?
I deleted both of them, and placed them again.  It does not help.
Any clue on this?
Thanks.
  • redwire
    redwire over 16 years ago
    Are you using the signal name on multiple schematic pages???
    If yes, you need to use a global power signal on each page and it will get rid of the _10944596.  That is added to make each "copy" of the signal unique which was not what you intended.
    If this does not seem to be the problem then zip up your DSN file and attach here or post a JPG of the schematic pages.
  • shangwu
     Yes, but how do I add a global power signal on each page?
    I also connected two symbols on the same page, but they don't connect in PCB Editor.  Aren't those 2 considered local?
  • redwire
    I am attaching a sample schematic that will show you.
    You can see a "global" power connector on page 1 and page 2 that is labeled "VCC_15"
    Then there is a "local" signal called "15V" on each page.  "15V" does NOT connect TP3 to TP7 because I did not use an off-page connector or global signal connector.   Instead OrCAD called the TP7-TP8 net "15V_401" in my design to make sure it was different from the TP3-TP4 connection.
    Hopefully the attached zip file will make it clear! :)
    LG1.zip
  • shangwu
     I'm attaching a Word file.  As you can see, I'm using off-page connectors.  Things work fine except the 3 single-pin connector on the left (P7, P8, P15).  They just don't connect to +15f, -15f and GND in PCB Editor.  I thought I didn't connect them properly in Capture, so I move them around and the traces/lines go with them.  So I assume they are fine in Capture.
    I tried using different symbols, such as the default single-pin symbol that comes with OrCAD, and the ones on the right (P25~P30, which work fine), but no luck.   Everything else, even on the other pages are connected fine, except the 3 pins on the left.
    I deleted everything and started from scratch, but the problem remains the same - not connecting in PCB Editor, only those 3 pins.
    capture_problem.doc
  • shangwu
    Ok, I think I got it now.
    I had to delete all the old files/netlists and put offsheet connectors on every sheet in order for them to work.
    I thought the global power and offsheet would connect (as long as they have the same name), but they don't.  I thought I had this years ago (by naming the global power and offsheet the same).  Is this a new feature from v9.2?
     Is there anyway to make all nets global that can go across different sheets?
