  3. Changing Layer Stackup
  • Views 21202
ace5582
ace5582 over 16 years ago
Is there a way to change the layer stackup without deleting all of my components? I originally made my design with the following layers:
 signal
pwr
gnd
signal
and I want to change it to:
signal
gnd
pwr
signal
I tried to change it by going to setup>Cross-section and renaming the layers. I also tried to delete them and remake them. When I tried to delete them I got the following error message: "Database error detected while trying to delete layer".
The only way I am able to change or delete the layers is if I delete all components and shapes on those layers. So I would have to delete all of my components and pours. Is there an easier way?
Thanks in advance.
  • redwire
    redwire over 16 years ago
    You're on the right track...for some reason Allegro is wrapped around the axle with the database error you're seeing.
    Back up one step and run "Tools- Database Check" to check/clear any existing layers.
    In the layer stack manager you probably just need to play a game like the following:  name the layers as follows
    PWR to GNDxx
    then
    GND to PWR
    then
    GNDxx to GND
    since you can't have the same name on two layers at once.  The layer name has NOTHING to do with voltages assigned so Allegro does not care what is connected.  You do NOT have to delete anything.
    Does that help?
    If you do have voltages attached to the planes then be sure to re-assign the voltages once you've renamed the layers.
  • ace5582
     It worked. Thanks redwire! I knew there had to be an easy fix :)
  • Tanveer
    Tanveer over 15 years ago
    Hi All,
    Is'nt there anyway two swap two layers in the cross section like I have the layer stackup below
    1-TOP
    2-GND1
    3-PWR1
    4-INR1
    5-INR2
    6-PWR2
    7-GND2
    8-BOTTOM
    Now I want this layer stackup
    1-TOP
    2-GND1
    3-INR1
    4-PWR1
    5-PWR2
    6-INR2
    7-GND2
    8-BOTTOM.
    Can't I just swap them or I want to follow the process of shifting and renaming?
    Regards
    Tanveer
  • Jagadeeson
    Jagadeeson over 15 years ago
    Hi Tanveer, You can do this by creating a dummy layer( temp layer) in between the PWR1 and INR1, then swap the PWR1 to that temp layer and then swap the INR1 to the PWR1. so now the contents in INR1 is shifted to layer 3 and contents of PWR1 is shifted to layer4 as per your stackup. Finally delete the dummy ( temp ) layer. Follow the same procedure for INR2 and PWR2 also. Hope it will work.
