  3. shape inside a symbol
  • Subscribers 166
  • Views 12402
stellar
stellar over 15 years ago
I need to include a complicate shape inside the symbol and it needs to net to ground. Is there a way to define the shapes net name inside the symbol editor?
  • Goblin59
    Goblin59 over 15 years ago
    In this particular case, I think the best way to handle this is to create an additional pin in the symbol and then create the pin shape you need in the PCB Editor. I saw your other post regarding the large amount of vias; have to think about that for a bit. Can you share what the component is? We could look up the spec sheet and perhaps help in your dilemma as long as it's not proprietary.
    Cheers,
    Ron Scott CID+
