  3. Is it possible to draw schematics based on netlist?
  • Views 16502
FZBarfield
FZBarfield over 15 years ago
We have the license for an old version of ORCAD, which is good enought for the small designs that we currently develop, both in wiring schematics and PCB design (using Layout Plus). Now we need to draw schematics for which the only information we have are the node list (given in Excel spreadsheet). We can convert the spreadsheet into a netlis. My question is: Is there a way to draw an schematic based on the netlist? I mean to draw the schematic positioning the components linked as defined in the netlist the same as we do when designing a PCB.
Please  advise
  • redwire
    redwire over 15 years ago
     Cadence offers such a tool (system designer???) -- contact them as they can fill in the details. Basically a spreadsheet form of design.
  • FZBarfield
    Thank you for your answer, I will contact them today.
  • luvishis
    luvishis over 15 years ago
    Cadence has a spreadsheet based product (Allegro System Architect) which can be used for applications like backplanes which have many large pin count devices connected to each other. Allegro System Architect might produce Allegro Entry HDL schematics only - check with Cadence if it creates OrCAD schematics.
    For generation of schematics from regular PCB netlists check www.elgris.com
    Elgris tool has the functionality to generate schematic from a PCB netlist and save it to OrCAD or to HDL.
  • FZBarfield
    Thank you. I will check all it out everything you suggest.
    Francisco
    Francisco Zaldivar
    Barfield Inc.
    Engineer
     Phone:  +1 305 894 5415
    Fax:       +1 305 869 2971
  • FZBarfield
    Francisco
