  3. Orcad Layout DRC issue
  • Views 12982
BTM73
BTM73 over 15 years ago
I have an issue where a padstack was not defined for inner layers for a particular pin and caused a short to the two plane layers. This was not caught by Layout's DRC but was fortunately caught by the PCB vendor. Any help in resolving this would be greatly appreciated.
Thanks!
  • redwire
    redwire over 15 years ago
     Check your error/warnings during artwork output -- bet it showed up there.  Allegro will let you produce gerbers with warnings. :(
  • BTM73
    Redwire,
    Thanks for the input. I checked the only report file I could find (.lis) and it actually states "No warnings or errors". That is scary that a tool will let you produce Gerbers with ANY error let alone an error that shorts every layer. Maybe that's why Cadence killed it. ;-)
