  3. Best Way to Explain Slots to Board
  • Replies 14
  • Subscribers 166
  • Views 18011
Goblin59
Goblin59 over 15 years ago
 All,
 I have a board shop (off-shore) that keeps kicking back my files because they have slots. As we know, we can generate the drill legend and the slots appear but the slots will not show up on the drill data (by design). What is the best way to explain this to a vendor? I'm really quite surprised they don't recognize this situation.
Cheers,
Ron Scott CID+
  • Carvey
    Carvey over 15 years ago
    We  add a detail view of the slot with dimensions and notes to describe what we want.
    For instance we want a finished plated width of the slot to be 0.043" and the total length to be 0.243".
    Therefore we would dimention the slot as follows;
    .200" between the drilled holes of 0.045" dia.
    Then locate the center of the slot for this feature.
    Note; this board was made here in the U.S.
    Carvey
  • discus
    discus over 15 years ago
    have you run the NC_route  in Manufcture - NC - NC_route.  This will created a slotted drill file.  I assume you have a slotted padstack.
     paul
  • Carvey
    Yes, we have a slotted padstack.
    We have not used the NC_route command as yet.
    Carvey Ready
    PCB Designer III
    Lester Electrical of Nebraska, Inc.
    (402) 477-8988 Ext. 114
    carveyr@lesterelectrical.com
  • discus
    if you have a design with slotted holes, you need to supply the PCB vendor with slotted drill file generated from the NC_route.  this will save you a lot of time putting the slotted notes in your drill drawing.
    paul
  • Carvey
    I didn’t know that.
    Thanks for the input.
    Carvey Ready
    PCB Designer III
