  3. Error [ALG0013] in Capture CIS 16.2
  • Views 14408
XpertDesigner
XpertDesigner over 16 years ago
hi All,
While generating netlist from Orcad Capture CIS16.2, following error is occured. Please help how it can be resolve
thanks in advance
#1 Error   [ALG0013] Conflicting values of following Component Definition properties found on 1C106 and 1C10 for part "0603C".
              VALUE
#2 Error   [ALG0013] Conflicting values of following Component Definition properties found on 1C107 and 1C102 for part "0402C".
              VALUE
#3 Error   [ALG0013] Conflicting values of following Component Definition properties found on 1C108 and 1C102 for part "0402C".
              VALUE
  • oldmouldy
    oldmouldy over 16 years ago
    By default, Component Definition Properties are going to be looking at Alt_symbols, Class, Part_Number, Tol(erance), Value, Power_Group, Swap_info, verify that these are the same on both components.
    From the log extract, it looks like the parts differ in the Value property which would take a bit of work with CIS connected to a database since it would be unlikely that parts in a CIS database with the same Part Number would have different values, unless the Part Status is out of date, or maybe a database is not being used. This could happen if a Part with a Part Number were copied and the Value changed without updating the design with Part Manager to get the correct database part linked.
    (The symbol(s) might have been edited locally, parts in the Design Cache like CAP, CAP_0, CAP_1 and so on, but this would be likely to give a different error.)
  • Michael Huawei
    Michael Huawei over 11 years ago
    PCR 402087 DEVICE property in Capture version 14.0 and later
    Description: The DEVICE property that was used in previous releases, is used differently in Capture 14.0 and later. However, the existence of this property in your design library can cause problems with the Capture-Allegro interface.
    Solution: In cases where your design library includes the DEVICE property (an anachronism from previous releases), you can avoid having to remove the property from each part in your library by employing the IGNORE_PROP property. To ignore the DEVICE property on a complete design, define IGNORE_PROPR as an environmental/system variable and assign it a value of "DEVICE."
    As with all environmental variables, IGNORE_PROP is specific to a system login. You must have administrative privileges to define IGNORE_PROP as a system variable. Also, you must restart Capture in order to read the new variable settings.
