  3. Tooling corner
  • Subscribers 162
  • Views 14294
Tooling corner
kabalee
kabalee over 16 years ago
hi
how to assign  (subclass) tooling corners in (class)  board gemetry ?
and
how to assign the  PHOTOPLOT_OUTLINE in board file? use of photoplot outline?
  • oldmouldy
    oldmouldy over 16 years ago
    Add>Line, set the Class to Board Geometry and the sub-class to Tooling Corners, set the line width as required.
    Add>Rectangle. set the Class to Manufacturing and the sub-class to Photoplot Outline. Note that NO DATA will be plotted to the artwork from beyond the photoplot outline defined, which is why most folks let this default to the drawing size.
