  3. Changing the component layer
  • Views 19185
gtaylor
gtaylor over 15 years ago
 I cant seem to find the answer to a problem im having with one of my designs in pcb editor, but how do i change the layer that a component footprint is on? While every other component is sitting on layer 'TOP', i would like one of the other components to be on layer 'BOTTOM' so that it can be mounted on the bottom of my pcb.
Is this possible?
  • KEN13
    KEN13 over 15 years ago
    Select the component.  Right mouse click and select mirror to move a component from top to bottom or bottom to top.
     Ken
  • gtaylor
     Thanks Ken, i did try that but i wasnt sure whether it was just mirroring the component, but leaving the silkscreen/assembly drawings on the top layer?
     So by mirroring, will the silkscreen be placed on the bottom of the board now (effectively tuirning it into silkscreen bottom)?
    Thanks again.
    Gary
  • KEN13
    Gary,
         That is correct.  It will switch anything from the top to bottom layer and the bottom to top.
    Ken
