  3. get drc's on pin delays when i change my cross-section brd...
  • Views 632
get drc's on pin delays when i change my cross-section brd thickness
jdkelly
jdkelly over 14 years ago
after my brd was designed i changed my cross section to input the correct info and my board thickness changed and i now get tons
of drc's on my matched lengths. i unchecked Z-axis delay and it still gives drc's. i want the correct cross section thickness,
but i don't want to change tons of matched lengths
  • redwire
    redwire over 14 years ago
     Did you re-run DRC check?  Some of these DRC's are sticky and you have to manually recheck DRC to clear.
