  3. .4mm pitch BGA
  • Views 14306
.4mm pitch BGA
Padmaster1
Padmaster1 over 14 years ago
First time using .4mm pitch BGA's. Please share some of your via setup and routing stratagies.
Currently I have it setup with a 12/6 via in pad with 2.5 mil traces internal and 3.5 mil spacing to drilled hole.
Still trying to figure out how to make PWR/GND plane fill between vias.
  • redwire
    redwire over 14 years ago
     Microvia is the best choice here.  Check out pricing.  It's cheaper than you think.
    That way you can drop the gnd down a layer; spread the signals out;  blinds down a couple of signal layers.
    Mentor published some great articles on bga breakout that goes over strategies.
  • Cadpro2K
    Cadpro2K over 14 years ago
     Try this doc:
    http://www.streamlinecircuits.com/streamline/sales/bga.pdf
  • Cadpro2K
     Another good site:
    http://www.circuitree.com/Articles/Feature_Article/BNP_GUID_9-5-2006_A_10000000000000953428
  • Cadpro2K
     nother good one:
    http://focus.ti.com.cn/cn/lit/an/spraav1b/spraav1b.pdf
