  3. ecl attached property etch length report
  • Subscribers 163
  • Views 15726
purikku22
purikku22 over 14 years ago
 hi all,
 is there a way to output only in a report the signals with attached ecl property?
 for example, SERDES signals. The etch lenght reports  seems to output all the nets.
thanks
  • mcatramb91
    mcatramb91 over 14 years ago
    You can either run the ECL Long and Short Reports from a DOS prompt using the Report command.
    ECL Long will report pin path length, total length and number of vias for all nets with the ECL Property attached.
    ECL Short will report total length and number of vias for all nets with the ECL Property attached.
    Type the following to generate a ECL Long report from a DOS Prompt:
    report –v ecl <Allegro .brd file> <output report file name>
    Type the following to generate a ECL Short report from a DOS Prompt:
    report –v ecs <Allegro .brd file> <output report file name>
    I could not find these reports from the Allegro GUI but they still seem to be available from the batch report command.
    Other alternatives are to create a custom extract view to generate a report or filter the nets out in Constraint Manager then export the active worksheet to Excel but these two reports are readily available and could be easily generated.
    Hope this helps,
    Mike Catrambone
    Plexus Engineering Solutions
  • purikku22
     thanks mike, it worked.
    have a nice day ahead!
