  3. Out of practice. Blind-Buried Vias in Allegro L.
  • Subscribers 163
  • Views 15482
Robert Finley
Robert Finley over 15 years ago
I need to stay current on drilling from layer 1-4 on an 8 layer stackup.  But, when I try to add a via to the fourth layer using the Add-via dialog box, I end up with via pads on 5-6 and 7-8.
 Am I reasonable to expect there is a way to go 1-2, 2-3, and 3-4 in Allegro L?  (yeah, I know bout the same-net DRC that I don't have.)
I do have a unique padstack for the microvia defined as single-layer in the padstack manager pad definition.
 Should the padstack name show up when I  check Setup>  B/B via definitions> Definte B/B Via?
  • redwire
    redwire over 15 years ago
     Remember that Allegro only chooses those valid vias which match the start and end layer shown in the options box.  Whenever you have the wrong layers chosen, Allegro reverts to a valid thru-hole via.
    Yes, you can do 1-2, 2-3, 3-4, etc... microvias.  Be sure to talk to your fabricator well in advance of this.  Have had good luck with MEI and DDI on doing stacked microvia technology,
  • Robert Finley
     Its been a while (year).  I was able to take an existing traditional SMT board, update the constraints to use the new via.  First problem is I created the blind/buried vias but didn't specify them in constraints (ok, don't get to change that too often.)
    Back to a via padstack defining the signal layer pad on outers and internal layer.
    Thanks for the fabricator advice.  I've done ALIVH designs in BS/BSRE, extensively.
     Is there a way to fool Allegro-L into allowing stacked/overlapped vias or does that require HDI in XL?
    It lets me place them adjacent to each other (touching), but DRC won't let them overlap.
    Next project is figuring out how to allow a blind via inside a component SMT land.
