  3. Shape to shape clearances
  • Subscribers 166
  • Views 16474
tabbey2656
tabbey2656 over 14 years ago
I have set up 3 different Spacing CSets. (using Orcad 16.3) All the spacing clearances are working as set up
in Constraints except for the positive shapes. They are still just using the default value for spacing which is
much smaller than I need. Has anyone else had this problem?
Thanks in Advance,
Tom
  • steve
    steve over 14 years ago
    It might be related to the shape parameter settings. Have a look at Shape - Global Shape Parameters, check the Clearances tab and make sure that Thru pin, smd pin and via all reference DRC as a default.
  • tabbey2656
    Steve,
     I took a look and everything is refererencing DRC. Appriciate the
    response.
    Tom
  • steve
    Tom
    The only other thing I can think of is if the shapes are static solid rather than dynamic. Use Shape - Change shape type, in the options fold out menu make sure the shape type is dynamic then select the shape.
    Steve
  • mcatramb91
    mcatramb91 over 14 years ago
    Tom,
    Display > Constraint can sometimes help in troubleshooting these types of issues.  See attached image.
    Hope this helps,
    Mike Catrambone
    Plexus Engineering Solutions
  • tabbey2656
    Thanks everyone. Finally found the problem. Using the Show Constraints window helped me realize that one of the nets was in the wrong netclass group. It's working now.
    thanks again,
    Tom
