  3. PDF output
  • Views 15390
PDF output
rwetz
rwetz over 14 years ago
Hi All,
I just installed release 16.5. I'm working ith PCB Editor, trying to create searchable PDFs of the top and bottom layers. I click on  File/Export/PDF... to bring up the PDF publisher screen. I can check the box for the top film and create a searchable PDF. All is good. Same for the bottom, but I would like to mirror the bottom so it looks like the real pcb. I don't see a "mirror" check box. I tried everything I can think of, but still no mirror. Is there a way to mirror the bottom film in pdf format? TIA
Bob
  • mcatramb91
    mcatramb91 over 14 years ago
    Hi Bob,
    I have been beating up the PDF Export for a little while now I have to admit I never thought about a mirrored PDF file (makes sense for bottom assembly views).
    My first idea was to go into the Film Record and click the “Film Mirrored” option which one would think the resulting PDF file would be mirrored – No dice, enabling the “Film Mirrored” option for the Film Record had no effect probably because the film records are only used to determine which layers to display in the PDF. I also notice that the wrong reading text (mirrored) comes out right reading (not mirrored) in the PDF file.
    Overall I think the PDF Export is a great addition to Allegro but with any new functionality there is always some kinks to work out.
    Let see if anyone else has any ideas on how to mirror the PDF output in 16.5 – if not it sounds like a great enhancement request.
    Hope this helps,
    Mike Catrambone
    Plexus Engineering Solutions
  • rwetz
     Hi Mike,
    I tried the artwork thing also. I also tried using the full Adobe software, but can't do it. I'm very green using Cadence, so I'm open to any ideas.
    Bob
  • RFDTeradyne
    RFDTeradyne over 14 years ago
    Some PDFprinters, such as PDFCreator, have an option to mirror the output. It is often hidden in an obscure "advanced" menu.
    If you have the full Adobe software, you could make a mirrored PDF and merge it into the PDF from the Cadence tool.
    By the way, I think the operation in Adobe Acrobat to "mirror" a page is "flip".
