  3. .drl file generation reg.
  • Subscribers 168
  • Views 17526
sreebabu1992
sreebabu1992 over 13 years ago
when generating NC drill file 'm getting the bellow error.
WARNING: Design precision is greater than that of the drill output file data.
Data rounding errors are very possible.
ERROR: The number of integer places specified for the
drill output data is not enough for this design.
  • girish
    girish over 13 years ago
    Check setup design parameters--->design ->accuracy.
    If the board unit is in mils set value as 2 & if it is mm set to 4  & In NC parameters FORMAT 5 ,5  then try generating drill file
    Girish
  • sreebabu1992
    Hi Girish,
     Yes, I got it.
     thanq very much.
    Sreebabu
  • jana211
    jana211 over 13 years ago
     Hi all,
              i designed an double sided board and tried to generate drill file, but it is showing the legend for only those components which r placed on top side.it is not showing drill legend for bottom side components.pls let me know how to generate drill data for all components.
                                                    thanks in advance
  • Hossein1357
    Hossein1357 over 11 years ago
    I am a beginner to Cadance PCB design and I am doing a simple project to learn it. I have the same message in my log file and I did your commands but I still see that warning. Although it has been changed to this:
    WARNING: Design precision is the same as that of the drill output file data.
    Data rounding errors may still be possible.
    Where else do I need to change to remove this warning completely?
    Thanks in advance,
    Hossein
