  3. PCB Editor and "find"
  • Replies 39
  • Subscribers 169
  • Views 33779
TH Designs
TH Designs over 13 years ago
When using the "find" feature, is there a way to have the screen go to the part you are looking for? Example, I'm zoomed in on a specific part of the board. I want to locate a part so I use the "find" feature and type in the reference desiginator. The screen remains where it is and I don't know if the part was found or not. Once I zoom out and start looking around, I see that the part that I was looking for was highlighted, but I was never taken to it. What use is the "find" feature if it does not take you to the part?
Example, in 15.7 hit "CTL-F" then type in the reference desiginator and return. You will be taken to that parts location.
Tom
  • Quarkdog1
    Quarkdog1 over 11 years ago
     I never got this working but here is something I use to do find with "Shift F".
    funckey F 'generaledit;set prompt;prompt 'Enter Ref Des';refdes $prompt;zoom selection;generaledit;pick grid 1.0 1.4;generaledit;hilight;setwindow form.find;FORM find name_type Symbol (or Pin);FORM find find_name $prompt;setwindow pcb;generaledit'
     Note:  my machine setup was not working with regards to highlighting thus the above code may be overkill for most but it works fine for me. :)
  • mvonahnen
    mvonahnen over 8 years ago
    ScottCad said:
    Thats ok if your zoomed out but useless if you are zoomed in on another part of the board.
    I guess that depends on what you are doing.  I like the feature of it not jumping and zooming to the part, so I can select the part and then move it to where I am focusing on the board.  I have Version 17.2 and I have not been able to get back to this "not jumping" mode.  Has this "bug" that I have used in the past been removed?
  • mvonahnen
    I was able to recovery the behavior I want by setting the following in the User Preferences Editor:
    Ui
    Zoom
    no_zoom_to_object (checked)
    If you are not zooming when you want to, you may want to check to see if this go checked.
  • Dale Peterson
    Dale Peterson over 8 years ago
    Tom,
    I glad you you posted this one. I have a guy at work that had your same problem. Mine always zoomed via the find window along with a few others. By the way on 16.6. i spent days trying to figure this one out. I notice that someone else stumble onto the bug which is in the Super Filter pull down. Here's what I did to fix the problem at my end to confirm his findings. Note: Just about everything we do is in Gen Mode. Not sure if this corrects things in the other modes however.
    1. Clicked on your design then right click Into the super filter to check the setting. Ours was set to off.
    2. Change super filter to Symbol.
    3. Selected a part for kicks
    4 Hit done
    5 Went back into the super filter and changed it back to off again and closed the filter.
    After all this the guy was able to get the the screen to zoom center of a part via the find window.
    Cheers
