  3. PCB Editor and Rats Display UI
  • Views 13981
Roger BFS
Roger BFS over 13 years ago
Perhaps I'm getting senile, but I can't seem to get rats to display when manually placing components.  Since this is a terribly convenient thing to have for optimal component placement, perhaps v16.5 made it go away?   Or perhaps I am suffering a Win7 or OpenGL display glitch?
When in PlaceEdit mode, I have Display > Show Rats > All selected.  The rats show up when I do a window selection of several components.  However, they disappear as soon as I select a single component to adjust its placement.  When I have a component "on the cursor" I only see a single randomly selected rat line visible from one pin of the component to some nearby component.
Can anyone clue me in to what I'm doing wrong?  Thanks.
Roger
  • Boma
    Boma over 13 years ago
    Try going to your general move command and in the options tab make sure "stretch etch" is unchecked.  Then try again.
  • Roger BFS
    Thanks Boma.  I finally found the "stretch etch" option and it is unchecked, although the first few times I tried from whatever "mode" I was in that didn't appear as an option ;-)
    But "Never Mind" everyone - I discovered what the problem was in poking around.  Somehow my color-display options had gotten set to "black" for the three "rats" objects.  Not very visible when you are using black for background color - duhh.  I don't recall doing that, so must be from some Cadence "default" settings somewhere along the line.
    Thanks for your help.
    Roger
