  3. Trace Length Computation
  • Replies 8
  • Views 19609
RRSQUAL
RRSQUAL over 13 years ago
Hello All,
I am trying to determine the trace lengths of addresses on a number of busses. These traces are within a "star" configuration with multiple loads. Setting up the pin pair configurations in the Constraint Manager works well for point to point, but is not accurate in this respect. Computing these lengths is very time consuming. Does anyone know of a skill file that may work for this?
 Thank you in advance.
-Rod
  • steve
    steve over 13 years ago
    Does the hover on the cline - RMB - Show Element (with nets only selected in the Find Filter) not give you what you want ??
  • RRSQUAL
    Hello Steve,
    Show Element gives me the entire net length, I need to break out each “branch” separately.
    -Rod
  • steve
    Hi Rod
    I think this is dependant on the rules that you have set via CM. At the top of the report I get
    Net Name:           Test
      Member of Diff Pair: Test1
      * user scheduled net *
        U10.E27 T.1 T.3 T.6 U43.F8 ; T.6 U20.F8 ; T.3 T.7 U22.F8 ; T.7 U45.F8 ; T.1 T.2 T.5 U21.F8 ; T.5 U44.F8 ; T.2 T.4 U42.F8 ; T.4 U19.F8
      Pin count:              9
      RatT count:             7
      Via count:              16
      Total etch length:      6603.445 MIL
      Total manhattan length: 8496.432 MIL
      Percent manhattan:      77.72%
    But further down I get:-
    (SPhase) U10.E27 to U19.F8  actual= 2982.679 MIL.
    Is this what you require ?
  • RRSQUAL
    Steve,
     Your result sounds like what I require. How are you setting up your CM to get this result?
    Rod
  • RRSQUAL
    Hello Steve,
     I know that I am close to these results, but, apparently, I am missing something in the CM to get this output. Any additional suggestions?
    Thank you.
    -Rod
