  3. Ratsnest minimization length
  • Replies 19
  • Subscribers 174
  • Views 21325
PcbAG
PcbAG over 12 years ago
Hi
I am a new user of orcadpcb and would like to know if it is possible to minimize the length of the ratsnest during the placement of a component and not after it is placed.
  • kabalee
    kabalee over 12 years ago
    place the component near to near so you can reduce the ratsnets
  • PcbAG
     Hi
    Yes, but this happens only after the component has been released during the movement ratnest is not updated.
  • steve
    steve over 12 years ago
    The tools don't work this way. The ratsnest is not dynamic. It will only update once you place the part down. You could assign a FUNCKEY to place the part down and pick it back up again which will update the ratsnest connections. Edit your env file to include
    funckey " " "pick_to_grid -cursor;pick_to_grid -cursor"
    This uses the spacebar to put the part down then pick it up again.
  • PcbAG
     Hi
     Thank you for your answer.
    I'm surprised.... even the cheaper cads have this function
  • RaylonS
    RaylonS over 12 years ago
    Is there an option setting for making the ratsnest 100% straight all the time? I am seeing often that some of the rats zig-zag off the origin and destination pin and this can sometimes be visually confusing.
