  3. netlist aborting
  • Views 19414
netlist aborting
shreeja
shreeja over 12 years ago
Dear all,
when im netlisting my design i had receive the following errors. this is the first time, these errors are came whem i'm netlisting. i dont know why this is came....? and how to correct it. anyone of you know how to correct these error, please tell me that. in this design im using a 48LQFP. most of the error came on that only.
{ Using PSTWRITER 16.5.0 p001Nov-08-2013 at 09:03:56 } #1 ERROR(ORCAP-36046): Conflicting number of parts per package (2) for U8A: SCHEMATIC1, PAGE1 (7.40, 7.90)#2 ERROR(ORCAP-36046): Conflicting number of parts per package (1) for U1: SCHEMATIC1, PAGE1 (3.40, 0.80)#3 ERROR(ORCAP-36036): Multiple pin 8's which have different nets connected for U8: SCHEMATIC1, PAGE1 (7.40, 7.90).Check for incorrect packaging of all devices in U8.#4 ERROR(ORCAP-36036): Multiple pin 2's which have different nets connected for U8: SCHEMATIC1, PAGE1 (7.40, 7.90).Check for incorrect packaging of all devices in U8.#5 ERROR(ORCAP-36036): Multiple pin 3's which have different nets connected for U8: SCHEMATIC1, PAGE1 (7.40, 7.90).Check for incorrect packaging of all devices in U8.#6 ERROR(ORCAP-36036): Multiple pin 1's which have different nets connected for U8: SCHEMATIC1, PAGE1 (7.40, 7.90).Check for incorrect packaging of all devices in U8.#7 ERROR(ORCAP-36036): Multiple pin 16's which have different nets connected for U8: SCHEMATIC1, PAGE1 (7.40, 7.90).Check for incorrect packaging of all devices in U8.#8 ERROR(ORCAP-36035): Multiple pin 1's which have different nets connected for U1: SCHEMATIC1, PAGE1 (3.40, 0.80).#9 ERROR(ORCAP-36035): Multiple pin 2's which have different nets connected for U1: SCHEMATIC1, PAGE1 (3.40, 0.80).#10 ERROR(ORCAP-36035): Multiple pin 3's which have different nets connected for U1: SCHEMATIC1, PAGE1 (3.40, 0.80).#11 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.
srimathi
  • oldmouldy
    oldmouldy over 12 years ago
    Try re-annotating the design, In Capture, select the DSN file entry in the Project Manager window, Tools>Annotate, Packaging tab, deselect RefDes Control Required, select Update Entire Design, select Unconditional Reference Update, select "(Prefered) Mode" and OK to re-annotate the design. Then try creating the netlist again.
  • Hossein1357
    Hossein1357 over 11 years ago
    I have the same problem and followed your instructions but it did not work. Again, after doing annotate I receive the same error and I see that there are two pins named AB16?! :-( I don't know how I can overcome with such error? I would appreciate any help.
    Hossein
  • steve
    steve over 11 years ago
    Try renaming one of the pins so that they are unique..........
