  3. Problem launching Design Entry CIS program
  • Views 18045
dmcentire
dmcentire over 11 years ago
Wondering if anyone has run into this problem. When I try and launch the "Design Entry CIS" program, it immediately gives me an error:
Capture.exe - System Error
The program can't start because cdsCommon.dll is missing from your computer. Try reinstalling the program to fix this problem.
At this point I don't want to reinstall the program, is there a simpler fix to this?
Thank you
  • oldmouldy
    oldmouldy over 11 years ago
    The first thing to check is that the cdsCommon.dll file is actually present, this will be in <installation_directory>\tools\bin, installation directory would usually be <drive>:\Cadence\SPB_<version> some security software can silently remove software components from the machine, re-installation is probably the only course to cure this and then persuade the security software to not scan and remove files from the Cadence installation.
    If the file is there, check that the system path is correctly configured to locate the file, the easiest way to check this is with a Command Prompt, type the "set" command at the Command prompt and check that the PATH correctly includes the full directory for "\tools\bin", entries like %CDSROOT%\tools\bin indicate a system problem which is causing the PATH entries to not be correctly expanded to <drive>:\Cadence\SPB_<version>\tools\bin, as in C:\Cadence\SPB_16.6\tools\bin for a default 16.6 installation.
  • dmcentire
    Thanks for the update. I have a new problem and I'm not sure if I need to open a new thread or not.
     I was able to find the missing dll and get that in place and working (modified the path).
     Now I get a new error, and this time the dll it's asking for is not on the computer anywhere, so I am definitely stuck now:
     capture.exe - System Error
    The program can't start because libsman.dll is missing from your computer.
  • oldmouldy
    This issue is almost certainly security software related since you cannot find the file. You will need to remove and re-install the software and then prevent the security software from scanning the installation directory and removing files. Be sure to install into a "neutral" directory, like the "Cadence" default, and not into an OS specific directory, like "Program Files"
