  3. Problem placing multi-part schematic symbol in Allegro Design...
  • Subscribers 163
  • Views 16051
Problem placing multi-part schematic symbol in Allegro Design Entry
mvonahnen
mvonahnen over 12 years ago
 I just built a new schematic symbol using the spreadsheet entry method.  It has 9 sections (Heterogeneous) and I can place sections B through I with no problem.  When I attempt to place section A, I instead get one of the other sections (usually the one after the last one I placed).
 Any idea what is causing this?
  • chads108
    chads108 over 12 years ago
     It woul be hard to tell without seeing the part data.  Have you tried bring the part up in Part Developer and see if it flags anything obvious?
    Chad
  • mvonahnen
    No.  I have not.  I am surprised because this part was not modified from another part (like adding or subtracting a part section).  I am able to place it by going to the last section placing it and then placing the first section, but I figured I gave having to do "stupid tool tricks" when I moved from Altium to Cadence.
  • chads108
     You shouldn't have to do "stupid tool tricks".  Something obviously went wrong in the creation of the part from the spreadsheet.  You should be able to place any section at will.
    Chad
  • mvonahnen
     I agree.  When I try to run part manager on the component, nothing happens.  Maybe my version does not support that.
  • chads108
     I would be willing to take a look at it if you want to ZIp it up and attach it, or send it to me privately.
