  3. Cross-Probing
  • Views 15413
Cross-Probing
Yoda5939
Yoda5939 over 12 years ago
All,
I have been trying to get cross probing to work with less than favorable results. I have AppNote from EMA and have been exchanging posts with the AE. In a previous life, I had cross-probing working just fine. I followed alll the instructions but it seems the system is mute. I selected ICT in Capture CIS and made sure I ran a new netlist and set OrCAD  PCB Designer in highlight mode. No go. I then placed the schematic and layout in a folder on the C drive because the AE says it has a hard time across networks. No go. The last thing is the AE has no problems with the files I sent, I'd like to get this thing going for my user's sake. I don't really use it but now that's known it exists I should be able to offer cross probing to my clients/colleagues. Any help will be apppreiciated.
-Ron Scott
  • WaltP
    WaltP over 12 years ago
    Hi Ron,
    I see that you have an open ticket with us on this issue.
    I suggest we set up web session to see what may be going.  Could be a system issue.
    Walt Pyska
    Manager, Technical Support
    Phone: 585-334-6001 x211
  • Yoda5939
    Walt,
    I scheduling time now and will be responding shortly. Folks at EMA have taken my files and ran cross-probing with no problem.. Files from EMA were sent back and I created a new folder with just the .dsn and .brd with no luck.
    Ron Scott
  • fxffxf
    fxffxf over 12 years ago
     Did you try installing the latest OrCAD pataches?
  • Yoda5939
    No, I haven't but has there been a feature change that would prevent this tool from not working?
    Ron Scott
