  3. Strange questions when generationg Artwork using Allegro...
  • Views 15311
Strange questions when generationg Artwork using Allegro 16.6
momo1982
momo1982 over 11 years ago
Hi all,
 First, thanks so much for your time spending on my post. I met a pretty strange question when I generate artwork using allegro 16.6. Since I am new to allegro, I will describe my question with enough details and pictures. I would appreciate your kindness if you can give me any help.
 I just finished a simple PCB design and the copper pouring. The next step for me would be generating gerber. I upload the picture of part of the PCB here, and this part is where the problems could be.
  • momo1982
    And I also upload the setting of artwork here so that you can see there should be no problem with the setting.
    Btw, I do DRC check ("Update DRC" in "Tool" menu) for the PCB, and there is no error. The DRC sign on the right-down corner is green.
  • momo1982
    Then, I clicked the "Create Artwork" menu in the artwork setting window. And I got error.
    A pop-up window tells me to check dbdoctor. I did it, and I found the error is :
  • momo1982
    It seems that allegro thinks it wrong to use the same via more than twice, because it says it is wrong to have the same padstack with the same name. You can see several via(s) and their name in first picture, and these via(s) are the ones mentioned in the error message.
    However, someone told me to do something I will list below to solve this problem. His solution works, but he didn't know why.
    The solution is:
    (1) First, click "Tools"--->"Database Check"
    (2) click "Check" button in the pop-up window, and then click "Performance advisor".
    Then, I got a window with information below:
    *  Performance checking for design D:/Work/Design/Power_Adapter_Board_Update_03182014/Gerber/PAB_V2.brd
    Ratsnest schedule check
    * OK.
    DRC checks
    * The number of physical/spacing csets is 0.125000 larger than the number
      of nets Suggest examining constraint model.
      ISSUE: Misuse of the Allegro constraint model such as using a spacing
             cset for each diffpair in the design. Result is system
             performance degradation.
    Constraint region check
    * OK.
    Dynamic shape check
    * OK.
    Sector table check
    * OK.
    Constraint set check
    * OK.
    NODRC_SYM_SAME_PIN check
    * OK.
    Cross section check for bad dielectric constant values
    * OK.
    Padstack size check
    * Padstacks have dimension that are far larger than the database would require.
      ISSUE: This may cause refresh symbol to take long time to complete.
        THR_CIR50_SQUARE100_CON2X1
    Conductor line check
    * OK.
    Design Constraints Statistics
      Physical csets       =     1
      Spacing csets        =     1
      Same net csets       =     1
      Electrical csets     =     0
      Other csets          =     0
      Total csets        ===     3
      Cset relation table  =     0
      Constraint regions   =     0
      Constraint shapes    =     0
    * OK.
    SUMMARY
    2 problems found. 0 maintenance problems found.
    (3) Then, he told me just close this window, and update DRC again. Then, re-generate the artwork.
    And the error I have shown above were gone! And I can generate artwork!
  • momo1982
    I am very confused about what had happened.
    1. First, from the original artwork errors, it seems that the vias with problems are the ones with name "VIA_CIR12_CIR25".
    However, in the message information provided by "Performance advisor", it doesn't mention this via stack at all, but mentioned another one "THR_CIR50_SQUARE100_CON2X1". And it also solved my problem without letting me know what was going on.......
    So, my first question is, what does the error in my 3rd post really mean? I mean the error "Duplicate padstack name found".
    2. what does the 2 messages below provided by "Performance advisor" mean?
    It mentioned 'database', which also appears in the setting window for artwork. The "Check database before artwork" dialogue is selected in the artwork setting window by default.
    What is the database here? What does it do?
  • momo1982
    All my questions are listed above.
    Thanks again for your time and patience!
