  3. After editing the schematic part, the symbols are not get...
  • Views 13280
After editing the schematic part, the symbols are not get updated in board?
Dhamodharann
Dhamodharann over 11 years ago
I had placed the component, then for the routing convenient the part pin has been swapped in schematic. After the swapping of pins i had updated the net list option. In that what option should i gave to board option.? In case i m try to update the net list means, net list fails The image is been below. Any solution for the problem occurs.
  • steve
    steve over 11 years ago
     If you have a board file already and you wish to import changes make sure that the import board is set to the original board. The rest are dependant on the license you have (Allegro, OrCAD etc).
  • Dhamodharann
    Thank you steve for reply. Then your solution has been tried. But in that also same problem occurs. i had gave the input file as original board file and netlist get updated. But that time also error occurs. Another method of trying to import the logic on File-----> Import-----> logic----> That option is not get worked.
  • Dhamodharann
    Steve i had done a mistake on import the logic on File-----> Import-----> logic----> . In this The directory has been target ed some other folder too. that make an problem.Now the schematic is get updated with the changed made in respective schematic is working.
