  3. How to install the Logo maker on Windows 7 OS ?
  • Replies 7
  • Views 16892
Dhamodharann
Dhamodharann over 11 years ago
Hi..
 I am trying to insert the company logo in the board file. For that i had downloaded the files http://community.cadence.com/cadence_technology_forums/f/27/t/13122 . In that i had download and install the precompiled potrace release.
My PC spec was Intel core 2 Duo with the 2GB RAM. But when i am try to install it, that time the cmd window is only executing. The software is not get executed.
So what version should be  downloaded  and what's procedure to install the logo maker with the potrace software. can anyone provide the possible procedure to install the logo maker.
  • eDave
    eDave over 11 years ago
    Carefully follow the instructions that I included in the file.
    Many have succeeded!
    Dave
  • Dhamodharann
          How to find out the suitable plat form for the windows 7 operating system? I had followed the instructions carefully.
         I had downloaded the pot race software recommended link.The software version is Potrace1.8.win32 -i386.zip. Then when i am try to install it, it executes in the cmd window such a long  long long  time.
        I cannot install the potrace? dave still me was facing the problems? The image is attached  for my problem occurred?
  • oldmouldy
    oldmouldy over 11 years ago
    You are running the potrace executable, this will only open a command prompt window if you run it stand alone. The potrace does not require installation, just the files copied to a suitable location for the logomaker to be able to run it, when required, during the logo image import. As Dave posted, follow the provided instructions carefully to install the required utilities.
  • Dhamodharann
    I can't able to download the ImageMagick-6.5.3-Q16-windows.zip. The latest version only available. But in that i can't find the .exe.
  • eDave
    I had no trouble finding the latest version at: http://www.imagemagick.org/download/binaries/ImageMagick-6.8.9-9-Q16-x86-windows.zip
