  3. Error during Simulation
  • Views 18964
Giridharan
Giridharan over 10 years ago
Please guide to solve below problem.
I have done many simulation. this is sudden problem.
Session log description
INFO(ORCAP-2191): Creating PSpice Netlist
INFO(ORNET-1041): Writing PSpice Flat Netlist C:\CADENCE\GIRI PROJECT\METRON\6 Parameter\6 Parameter-PSpiceFiles\SCHEMATIC1\SCHEMATIC1.net
INFO(ORNET-1169): Unable to open the property mapping file: devparam.txt. To resolve this problem, ensure that PSpice.ini exists at the correct location. After that check Library Path in simulation settings contains <installation-path>/tools/pspice/library path and then create the netlist again.
INFO(ORNET-1162): Unable to create design property file.
  • oldmouldy
    oldmouldy over 10 years ago
    It looks like PSpice cannot find the "base" configuration files when the simulator starts, go to PSpice>Edit Simulation Profile, Configuration Files tab, select Library at the upper left of the form, check the Library Path setting at the middle bottom of the form, highlight and delete any current value but it will probably be empty anyway, then use the lower browse button to browse to the "tools\pspice\library" directory of the product installation and add it as the Library Path. Also check that you have "nom.lib", or "nomd.lib" for the unlicensed version, as Global in the configured files section. Then OK the Simulation Profile form.
  • Giridharan
    INI File Location:C:\Users\MURALI\cdssetup\OrCAD_Capture/16.6.0/capture.ini
    INFO(ORCAP-2282): The following 8 points have been identified as net connectivity change points from the last operation
    (5.80, 3.30)
    (6.30, 3.30)
    (5.60, 3.30)
    (6.10, 3.30)
    (5.90, 3.30)
    (5.70, 3.30)
    (6.20, 3.30)
    (6.00, 3.30)
  • Giridharan
    Please guide to solve below problem,
    INFO(ORNET-1041): Writing PSpice Flat Netlist C:\Cadence\Giri project\Metron\6 Parameter\6 Parameter-PSpiceFiles\SCHEMATIC1\SCHEMATIC1.net
    ERROR(ORNET-1019): Pin PWR in template not found on U9
    thanks for u kind information its more useful for me,
    Giri.
  • Giridharan
    could me please help me one more doubt their i have, i need to create library for 16*2 LCD display in orcad capture cis 16.6 lite, i getting the error, please solve me this error.
