  3. Can a cutout be added to a footprint?
  • Subscribers 167
  • Views 14627
pdxbtw
pdxbtw over 10 years ago
I'm new to PCB editor and I need to make a footprint for an RF connector that sits into a cutout on the edge of the board (and is edge plated around the cutout, ideally). I have to place more than a dozen of these connectors and I would like a way of easily moving them if I need to. Is there a way to add a cutout to a footprint so that I only have to place one object?
  • steve
    steve over 10 years ago
    Yes - Draw the cut-out on Board Geometry / Outline, add keepouts s required. Then place in the board. You'll have to draw your actual board outline using lines to "fill in" the gaps between the connectors but there's no issue with this.
  • docb
    docb over 10 years ago
    Seems to me you would add a mechanical pin to the part, and instead of a drill in the padstack, use a route. Essentially what you'd do for a thru hole part, but a big square instead of a circle. Make sense?
  • pdxbtw
    Some what. At this point I think I need to take a course or some type of training. This is my very first PCB I've made and it seems like this might be out of my skill level at the moment.
  • docb
    In some ways Eagle is easier for beginners, just because of the support and community. OrCAD is better if you can fight thru a bit.
